DOHC motor swapJSUsaxman 01-27-2006, 06:34 PM I have a 97 SOHC and I am going to put a DOHC in it. What other parts if any besides the motor do I need for this swap? rsublime4life 01-27-2006, 06:49 PM Computer for one neon_rt 01-27-2006, 06:53 PM You will need the wiring harnesses for the fuel injection/ignition and the computer. You may be able to use the SOHC computer but the tuning might be off some and the rev limiter would be too low. If you have a ATX then I would not recommend the change, MTX should be fine, although since the DOHC doesn't put out as much low RPM torque, it may feel more sluggish in high gear while cruising. das2123 01-28-2006, 01:27 PM I have a 97 SOHC and I am going to put a DOHC in it. What other parts if any besides the motor do I need for this swap?Read this post, it covers everything you need for the swap... http://forums.neons.org/viewtopic.php?t=80202 JSUsaxman 01-30-2006, 11:09 AM What all motors will fit in a 1st gen neon????? das2123 01-30-2006, 11:35 AM What all motors will fit in a 1st gen neon?????All neon engines including the SRT-4 and 2.4L engines from a stratus or PT cruiser will fit with modifications. These are the reasonable swaps for the 1st gen neon, but with enough time and money you can make most engines fit, but the cost will be outrageous! wafrederick 02-02-2006, 07:43 PM The computer.The used one might start it up if you are lucky.If it does not start with the used 2.4 computer,you will have to get a reman from Chrysler and it has to be progamed.Only way to program the reman chrysler computer is use Chrysler's factory, scan tool DRB III or a Vetronix scan tool,Master tech. das2123 02-02-2006, 07:47 PM The computer.The used one might start it up if you are lucky.If it does not start with the used 2.4 computer,you will have to get a reman from Chrysler and it has to be progamed.Only way to program the reman chrysler computer is use Chrysler's factory, scan tool DRB III or a Vetronix scan tool,Master tech.As long as they use a DOHC computer for the year of the neon it will start up and work fine. There is no need for all that other stuff. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
