90 Bonnie wont start...need helptha_schmidt 01-25-2006, 03:01 PM My 90 bonnie SSE will start first thing in the morning. Then after its been driven a while and turned off, when I attempt to start it agian it just churns and churns but never kicks over. Let it sit for several hours, and then try again, it starts right up. I replaced my coil pack, still no change. I checked for spark and I have no spark. I have been told to look into an ignition module, however I wanted to make sure it wasnt just a relay or something else. I found my relays under the passenger dashboard, but none of them are labeled. Anyone have a chart that labels the relays, or has anyone had this exact same problem that might be able to direct me in what to do next. Thanks 1997bonneville 01-26-2006, 09:49 AM The labels should be on the back of the kick plate that you removed to get to the relays. brcidd 01-27-2006, 03:07 PM check for ignition voltage at the coil in BOTH the "run" and "start" positions tha_schmidt 01-30-2006, 04:29 PM Ok, thanks everyone for the reply's. First, there wasnt a kick plate that I took off to get to the relays. They were behind my glovebox. I just removed the glovebox and there is a panel of relays and a few fuses. The fuses I have a list for in my Pontiac manual. The relays arent labeled anywhere. Next, I had my ignition module tested at Autozone and it tested good. So thats one less thing. Now I am trying to figure out which of the dozen wires going to the module is the power wire. I will check for power with key in "on" and "start". Small setback, my battery went dead so I have to wit till Friday to buy a new one. Sit tight guys, and thanks again for helping me out, I really need to get the Bonnie back on the road! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
