Radiator Fan Relaydkwilborn 01-19-2006, 10:37 AM I have an 2000 Dodge Durango and I have an error code that is referencing the radiator fan relay. Does anyone have a fix for this error. I am overseas and parts and maintenance is limited. MT-2500 01-19-2006, 11:33 AM Like what code no.? Like what eng and trans? If there is the same no relay in the relay box switch them and see if it helps. The code will need to be cleared with a scanner to remove it or you will have to drive so many drive cycles for code to clear after fix. MT Stevo2 01-21-2006, 06:54 PM I have an 2000 Dodge Durango and I have an error code that is referencing the radiator fan relay. Does anyone have a fix for this error. I am overseas and parts and maintenance is limited. Have any fuses blown? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
