Misfire Code P302jekmech 01-18-2006, 08:57 AM Have a 1999 Grand Cherokee six cylinder which in the past two weeks has several times been difficult to start and then misses and carries on. Check engine light comes on. Shows a P302 misfire code for cylinder two. The problems is intermittent with the vehicle starting and running fine for several days at a time. What should I look for in order of the most likely problem. Bob D. 01-18-2006, 12:27 PM Bad injector, spark plug, coil pack. Injector would be my first suspect, when they leak they don't set codes. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
