2000 f150 shudders b4 o/dfishsixworkone 01-18-2006, 05:48 AM it runs out ok b4 it goes into od then it shudders like heck, also when idling it seems to have miss , any connection ? thx way2old 01-18-2006, 09:15 AM If it has a misfire, the truck will do what you are describing. If it only does it at a shift point, have the transmission completely flushed. transgta 01-19-2006, 06:42 PM Have u ever changed plugs it did help mine a lot but when its in od the revs drop and it misses worse. Also at stop lights mine kinda pulses. But do check the plugs RahX 01-20-2006, 12:10 AM yes do like way2old said and have it flushed. make sure the shop uses MERCON V. i dont know how many fords ive experienced this on and the tranny flushed cured it. fishsixworkone 01-20-2006, 05:30 AM thank you all for your help, I took it to ford and the diagnostic was a cracked coil and a bad plug wire. Now it runs good. again thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
