No Low-beam Headlights On Honda Civic!?!?!
HONDA_TEC
01-16-2006, 09:22 PM
HI ALL, I HAVE A 93 HONDA CIVIC HATCH THE LOW BEAMS WORKED BUT NOW THEY DONT!!!??? ALSO I CHECKED THE FUSES ITS NOT THAT ANY SUGGESTIONS????:grinyes:
prototype80
01-17-2006, 02:51 AM
have you checked your bulbs, also is ther anything you have done to your car here recentlyie playing with wires and such that could have coaused this problem to have come up. i had some cheap ass prjectors i kept blowing bulbs in, so that could be the problem right there is you do have projectors.
HONDA_TEC
01-17-2006, 09:02 PM
Hey See My Car Is All Stock Exept The Intake I Have An "aem" Cold Air Intake And I Have A Very Nice Exhaust System But When I Saw That There Was A Headlight Out I Replaced The Fuses And Fixed It But Now When I Turn On My Low Beams Only The Corners Come On My Radio Was Stolen Before I Had Gotten My Awsome Car And Then I Tryed To Wire Up The New Radio My Self But It Didnt Work So I Had It Professionally Installed Any Ideas Maybe The Wiring From The Firewall To The Headlights Is F**k Up Ima Bout To Replace It To See Any Suggestions?!?!?!?!?!?!
TurboLaxx
01-17-2006, 10:51 PM
OMG, try and break this into more than one HUGE sentance. Also please dont capitolize every word, it makes it very hard on the eyes. I dont know where one sentance starts or ends...
Messing with the radio wont kill your lights. Pull the bulbs and see if the filament wire has broke. Remember to not touch the bulb's glass part. Only handle it by it's metal neck. Most likely your bulb's low beam burnt out.
Drift King
01-18-2006, 01:44 AM
Hahahaha!:lol:
HONDA_TEC
01-19-2006, 09:45 PM
:banghead: Hey, srry bout the caps but i replaced both of the eadlight bulbs before i ever even started this thing on here (i think its the wiring from the firewall to the headlights its should be a simple snap offf snap on :banghead:
alfonso2501
01-24-2006, 09:51 AM
HONDA_TEC please tell us why you replaced the fuse again, I really didn’t understand. Also what do you mean by “eadlight”? Do you mean tail lights?
HONDA_TEC
01-24-2006, 06:57 PM
HEY SRRY ABOUT THE MISPELLED WORDS WHAT I AM TALKING ABOUT IS THE LOW BEAM HEADLIGHTS WHEN I HAD GOTTEN MY AWSOME CAR I HAD TO REPLACE A FEW OF FUSES OK LIKE FOR THE DOME LIGHT (THE LIGHT ON THE ROOF IN THE INSIDE) AND A HEADLIGHT WAS OUT, OK SO I REPLACED THE FUSES AND EVERYTHING WORKED EVEN THE LOW BEAMS BUT NOW THE LOW BEAMS DO NOT WORK WHEN I TURN THEM ON THE CORNER LIGHTS COME ON WHICH THEY ARE SUSPOSE TO ANY SUGGESTIONS THEN PLZZ HELP..............:confused:
Copytech99
01-24-2006, 09:23 PM
I would be willing to go to the library and print out the schematics for the headlight wiring if that will help. Most of the systems provide power to the bulbs common lead and switch the grounds ( I would have to take a look myself though)
Is it an DX or LX ?
HONDA_TEC
01-25-2006, 06:41 PM
:mad: HEY, ITS A DX, AND CANT IT BE THE PLUGS BECAUSE THEY LOOK A LITTLE DIRTY???:mad:
alfonso2501
01-26-2006, 02:23 PM
...When I Saw That There Was A Headlight Out I Replaced The Fuses And Fixed It But Now When I Turn On My Low Beams Only The Corners Come On...
My guess is that you might have replaced the defective fuse with a wrong one. Or you might have replaced the bulb with the wrong type. Only a guess now. And no, you're spark plugs don’t have anything to do with it. Does anyone else have an idea?
HONDA_TEC
01-26-2006, 09:09 PM
I DIDNT MEAN THE SPARK PLUGS WIRES I MEAN THE HEADLIGHT PLUG THAT CONNECTS INTO THE BULB INTO THE HEADLIGHT...........:banghead:
Copytech99
01-26-2006, 10:53 PM
To the OP, I will get the wiring from the library on Jan 27th if possible, Would you please PM with E-Mail and I will scan them once they are printed.
Copytech99
01-28-2006, 01:14 PM
I have a print for you. It is not the exact year as yours but may be of help. PM if still needed.
