1997 Dodge Grand Caravan Oil Warning lightthayes9572 01-12-2006, 11:46 AM The oil warning light and chime starting coming on a few days ago. Oil has been changed and level is OK. Light does not come on when car is in reverse or when I take my foot of the gas. Any suggestions? The Mailman 02-14-2006, 07:54 PM same problem here too......anyone with suggestions?? moparman58 02-15-2006, 02:20 AM According to Haynes, when the oil pressure light comes on, the order of things to check are: 1. Low oil level (you already checked) 2. Short in wiring circuit 3. Faulty oil pressure sender 4. Worn engine bearings/oil pump Hope it's 2 or 3. Hope this helps! Stevo2 02-16-2006, 03:07 AM Change the sender unit. HeadlessHorseman 02-23-2006, 04:25 PM Replacing the sender unit worked for me. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
