96 neon problem list
realalam1
01-12-2006, 05:58 AM
Here is the problems.
Gas gauge does not always work.
Speedometer does not always work.
Battery charge light is on.
Error code 12. Problem with battery connection.
Error code 44. Battery temp in PCM.
I think all my problems are from a bad PCM, has anyone seen this before? Its the PCM or the wire harness.
das2123
01-12-2006, 07:39 AM
Speedometer does not always work.Read this post to fix these problems...
http://www.automotiveforums.com/vbulletin/showthread.php?t=480855&highlight=gauge+cluster
Code 12 - battery has been disconnected within the last 50 key-on cycles (Nothing to worry about)
Code 44 - Battery temp sensor volts out of range (your battery sensor may be bad, it's in the battery tray on the right hand side if you are standing in front of the vehicle)
realalam1
01-12-2006, 06:16 PM
A COLD SOLDER JOINT? Will this because of a cold solder joint. I'll try the fix.
Now for the battery temp sensor, where can find one? Parts America doesn't show them as an item they carry. Is it a dealer only item?
das2123
01-12-2006, 09:09 PM
Fix the cluster first, that may be whats setting off the battery sensor. You never know. The gauge cluster needs to be reflowed.
ryandotcom
01-18-2006, 09:35 PM
I just bought a 96 and i noticed after i use about 4 gallons the gas gauge goes to empty then dances up and down. The other problems havent showed up yet.
das2123
01-19-2006, 08:03 AM
I just bought a 96 and i noticed after i use about 4 gallons the gas gauge goes to empty then dances up and down. The other problems havent showed up yet.Sounds like your fuel gauge sending unit(sensor) is going out on you. It's attached to the side of the fuel pump module.
