HC (PPM) emission test FAILED!
sibrian
01-11-2006, 11:35 PM
Hi people, I'd go to an inspection location today, and I couldn't pass inspection because the HC was high, about 40 points above the Texas standard reading. Inmediately, I'd change the Oxygen sensor, which was not working, and I did put a fuel system treatment to my car. I'll change the PCV Valve also, so, what also do you recommend me to do???
Also, I found oil in one of the spark plugs today, I don't know what was it doing there, but I know It shouldn't be there, What can I do to fix the problem???
calicelica
01-12-2006, 03:36 AM
replace spark plugs and cable (definitely) + distribution cap and rotor (check this)... from what I know, you're also losing power (running rich??) maybe its misfiring. Try resetting the ECU after that too.
calicelica
01-12-2006, 03:43 AM
oh btw, when you install the new plugs, make sure it sits tight and secure. The same leak happened to my roomate a while ago, due to bad workmanship and very old liquidy oil. Change oil, I recommend regular 10w-30 although its winter...add "prolong" if u want. I did, and it helps "relaxes" my 130k miles engine down a bit :)
91 Celica St
01-12-2006, 08:19 PM
run your car for a long time before going to smog, this allows the cat to heat up...id say go drive up and down a little mountin then go get it smogged, re-set the ecu just beofre you get to the shop
sibrian
01-13-2006, 11:02 PM
Ok, thank you.
