Loud Roaring in front end
Google
Web AF
halgreer
01-11-2006, 12:42 PM
My 98 Blazer has a loud roaring sound in the front end while driving. It becomes annoying after a ride of some distance. It also has quite a bit of play in the steering wheel. Tire replaclement has not helped. Don't know which way to turn.
DetroitMuscle
01-11-2006, 01:34 PM
roaring like a lion or bear or roaring like mechanical noise?
halgreer
01-11-2006, 02:56 PM
roaring like a lion or bear or roaring like mechanical noise?. The sound is like that of tires with very thick threads. It resonates throughout the passenger compartment. Is there a problem with the suspension?
blazee
01-11-2006, 03:04 PM
There are several possible causes, one of the most common is the wheel bearings. Is the sound accompanied by a vibration? Does it get worse while turning in one direction and seem to get better while turning the other? Is it in sync with the speed of the vehicle? Does it seeming to be more noticible at speeds between 25 - 45?
As for the steering, check out this thread:
http://www.automotiveforums.com/vbulletin/showthread.php?t=503647
and also search for a thread called "facts about steering slop" (something similar to that)
bog
01-22-2007, 09:30 AM
Hi all,
Just found this board, while searching for this same problem/solution.
This is exactly the problem with my '04 2WD blazer. It doesn't matter the speed. The car sounds like I've got huge mud grip tires on it, but it has plain, street tires. I notices yesterday, that the noise stops completely if I turn right or if a bounce (like going over a bridge on the highway) takes some weight off the wheels.
tia,
Bog
RexT
01-22-2007, 08:03 PM
your probaly just not used to hearing such a tough motor:grinyes:
paxfam1
01-23-2007, 12:39 AM
Sounds like your passenger side bearing is done.....Replace the hub/bearing assembly..........
bog
01-23-2007, 08:40 AM
lol, Rex... That may be true, but only if the engine somehow got tougher over the past year.
Thanks, paxfam1. Any idea how much parts would be for that?
chubbygoatboy
02-03-2007, 08:30 AM
Front wheel bearings, and these are also well known for ball joints, tie rods, pitman arms, etc. Basically the entire steering-chassis connecting parts. I have replaced many. But your roaring is wheel bearings!!
paxfam1
02-04-2007, 02:52 PM
As for the price, Autozone has them for $120.99. Its a pretty easy install, but be sure that you grab that axle socket if you dont have access to one.
Post your results!
paxfam1
Google
Web AF
