1998 Park Avenue door handle replacment
bmostyn
01-10-2006, 08:07 PM
I need to replace the drivers side door handle. Can anyone tell me how to remove the handle. I have the door panel off, but cannot access the handle. Need help please. Thanks. :1zhelp:
Loekee75
01-11-2006, 08:59 AM
Can you see the back of the handle from inside the door? The door handle has a connecting rod attached to it. This rod is connected with a rotating plastic clip. After removing this rod, you'll have better access to the bolts that hold the handle in place. After removing these (I believe it's 2 bolts) the handle will come right off. Make sure you keep the rubber gasket from the outside in case you didn't get one with the replacement! If you have any more questions about this feel free to pm me
