How many O2 sensors
swinsoneric
01-10-2006, 07:45 AM
I was wondering how many O2 sensor are the in the back by the cat conveter, i am having bad fuel mileage, i changed the fuel pressure regulator and i'm still having the problems. so do you think changing the O2 sensors would be good..........i changed the one in the front about 2 months ago... Any help would be appericated.
maxwedge
01-10-2006, 09:37 AM
A scan and a graphing scan will tell you if the sensors are weak or you are just spending money here on guess work. The post cat sensor has no affect on performance.
swinsoneric
01-10-2006, 11:24 AM
Where can i get a scan or graphic scan done at ?
maxwedge
01-10-2006, 07:22 PM
Most good garages out there have a scanner or scope capable of looking at 02 sensor activity, obviously a dealer does, but this may cost up to 1 hour labor at the going rate.
swinsoneric
01-11-2006, 12:16 AM
just one quick question, there are two sensors....right ? One upfront and one in the back
slls
01-11-2006, 03:21 PM
Yes, for each cat.
ermel
01-11-2006, 06:09 PM
Autozone Stores, I think, gives you a free scan! At least the ones around here in Central Jersey do. Hope that helps!
wafrederick
01-12-2006, 08:07 AM
There should be 2 of them,one in the exhaust manifold and one behind the cat.Do not take to AutoZone(really called AutoJunk),they do not use a scan tool,they use what is called a code reader.
