Lean Fuel Mixture on 96 Neon
ChucksJimmy
01-08-2006, 10:28 PM
My dads 1996 Neon with 38K miles has a Lean Fuel Mixture Code that routinely comes back after I reset it with my reader. In the last year the dealer has replaced the head gasket. I have replaced both O2 sensors, the EGR valve, MAPI sensor, IAC valve, spark plugs, wires, and just recently the Throttle Body Sensor switch (because the voltages were low when I checked them). I have checked Fuel pressure and checked the fuel injectors and they seam fine. I am lost...help from anyone would be greatly appreciated....Thanks.
das2123
01-10-2006, 08:46 AM
That is odd because neons usually run rich if anything. I would have to think it's something to do with fuel pressure if not your fuel injectors. Again, this is speculation. I would swap in some new fuel injectors, it's easy and doesn't cost that much.
ChucksJimmy
01-10-2006, 06:23 PM
Thanks for the reply. Thats what I'll replace next. Everything else is fairly new on it unless the EGR vavle went after a year. I monitored fuel pressure two seperate times with the same results. It was well within specs listed in the Hayes Manual. Thanks for the reply...
