Motor Swapram3736 01-06-2006, 11:44 PM I recently blew a hole in 3.1L V6 motor that had 75,xxx miles. While taking the radiator off, it leaked RED fluid out of one of the bottom hose connections. I didn't trace the line back to anything, could it have been for the radiator? How hard is it to unbolt the motor from the transmission? Can I just undo the nuts on the bellhousing and separate it or do I have to unbolt the flywheel from the torque converter? It is a 1998 Chevy Malibu LS 3.1L V6 Auto. with 75,xxx miles on the motor. malibugtp 01-07-2006, 02:05 AM if your dooing a swap, swap it for a 2000+ 3100 or 3400 out of a grand am or alero gapboi210 01-07-2006, 06:40 PM The red fluid was transmission fluid. The raditaor also has a few lines going through it as a trans cooler. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
