2001 Keyless Entry
Google
Web AF
frca05
01-06-2006, 04:52 PM
I read on another thread (that is now closed) that you have to have a GM scanner in order to program a keyless entry for my car. I was hoping there was another way, but since there doesn't seem to be, is there any way to find out where I can do this?
Onblsht
01-12-2006, 02:37 PM
You can try the instructions that work for 99-00 models, since some 01 units have worked this way.
Important
Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry programming/diagnostic mode. This prevents the programming of the transmitters to the incorrect vehicle.
Up to 4 transmitters may be programmed.
Transmitter Programming Procedure (Method 1 - No Tools Required)
To program the transmitters, perform the following procedure while seated in the vehicle driver's seat:
Close all the vehicle doors.
Remove the ignition key from the ignition lock cylinder.
Press and hold unlock on the door lock switch.
Important
To successfully enter the keyless entry programming/diagnostic mode, steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully.
Repeat step 7 for the rest of the transmitters (for a total of 4 transmitters).
To exit the transmitter programming/diagnostic mode perform either of the following:
Turn the ignition switch to the RUN position.
Remove the ignition key from the ignition switch.
eprince
01-12-2006, 06:05 PM
Important
Important
I just had my remotes programmed for my 2001 grand am se
They make two types for that year so make sure you buy the right one,
I mached the numbers on the back of my existing remote. The dealer could not get his scanner to talk to the reciver and wanted me to pay for troubleshooting the proublem. as it turned out there is no seperate reciver for my car it is part of the BCM. After he looked it up in the manual it only took a minute to reprogram the remotes. It cost me $40.00
Google
Web AF
