no crank
yorkmix123
01-05-2006, 04:28 PM
97 jgc limited auto
turn key there is nothing happen on the engine front
engine does not crank
all lights work interior and exterior
alarms ok i think,tried unlock doors with key to reset
only error code i get is 12,which i dis the battery the other day
starters ok checked that
checked all fuses
jeep was ok before this happened
any ideas please
ps.hello to eveyone new here
yorkmix123
J&J56
01-05-2006, 07:23 PM
Have you checked the wires at the starter. It sounds like one of the wires is loose.
dksob81
01-05-2006, 09:38 PM
Are you sure the jeep is in park? If so, try to start it in Neutral.
oljeeptek
01-06-2006, 01:41 AM
Make sure the start relay is also good.
yorkmix123
01-06-2006, 03:08 PM
got the jeep going by crossing the two bolts on starter
took it for a run hoping it might reset jeep
stopped jeep tried to start not a thing
ive heard there is two starter releys does anybody know is this right,if so where are they
thanks
Goldfishy
01-08-2006, 02:25 AM
Bad battery or on it's last leg.
solid15
01-15-2006, 10:23 AM
I am new here, but these are the same exact issues that caused me to join. I have the same vehicle with the same issues. After way too much time (and a CPS replacement), it came down to a loose negative battery connection. Check the wires going into your terminal connection, not just the battery post connection.
