Question 4 Yall About Sound Systembosox424221 06-10-2002, 11:18 AM i have a 2002 toyota tundra standard cab, meaning no back seat, so i have about 12-14 inches in the back of my bench seat, what i want to know is what kinda sytem i should buy (head unit, amp, sub's) and how i should install it, thanx j.:D kauperid 08-21-2003, 04:47 PM Do you know how to remove the trim on the Tundra? I've gotten as far as removing the screws behind the Fan and A/C switches but still can't get to the radio. ToyTundra 10-08-2003, 07:02 PM did you get the screws behind the air vents? Point the vents up and take a look. After that the black part just pulls off. There are 4 or 5 srews total. kauperid 10-10-2003, 06:03 AM It worked, it worked! Thank you so much, darn Auto manufacturer's keep getting better at hiding those attachment points! walway 12-15-2003, 07:53 PM any idea how to take the radio out? 2002 tundra kauperid 02-15-2004, 03:08 AM any idea how to take the radio out? 2002 tundra Once you get the trim panel off (the screws behind the vents stumpped me) then the radio just comes out with 4 screws 2 on each side of the unit. it should slide out of the mounting bracket then and you can put in whatever radio you want. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
