1999 Lumina LTZ Guage package
RHoschett
01-03-2006, 07:55 PM
How do I remove the cluster package from my dashboard to change the lite bulbs? all but one are burned out...getting to it from underneath the dash does not seem possible...
maxwedge
01-03-2006, 08:00 PM
The surround bezel around the cluster then remove the cluster.
RHoschett
01-04-2006, 12:00 AM
How does this come out?
cadgear
01-04-2006, 01:44 AM
The knee bolster/kick panel under the column comes off with two screws and two other retaining clip screws. Drop the kick panel, then tilt the column all the way down. If you have column shift, key on and put in 1st, then gently remove the dark bezel around the AC controls, dash, radio, and headlight switch (all one piece)
Unbolt the cluster, pull it out enough to unclip the connector, then replace bulbs. Column shift, be wary of the PRNDL indicator that you need to disconnect to remove the cluster.
Installation is reverse of removal.™
RHoschett
01-04-2006, 09:45 AM
Great Advice! I have an LTZ, so no column shift..Cluster is out, bulb is #194 and I'm replacing all of them so I dont have to take this thing out again next week. Next step tho, when I did this I lost the middel third of lights in my radio front panel..are they replaceable too or do I need an entire front bezel?
RHoschett
01-06-2006, 01:42 PM
Problems solved! I replace dall the bulbs in my dash with either the #194 or #161 per spec sheet I got off the inet. I visited my dealer to get the bulbs for the a/c heater controller (@ $7.00 ea.) and got the LED bulbs for my radio front panel online (@ $2.00 ea) $60.00 bucks later my dash glows like the day they made it...
mqqn
02-05-2006, 02:00 AM
Hi RHoschett -
Where did you get teh replacement LED's and how much of a job was it to put them in the radio head unit?
Our 98 LTZ has the same issue - a couple of cluster lights burned out and the radio buttons are burned out as well.
thanks and best regards-
mqqn
paulfischer
02-05-2006, 10:10 AM
I'm interested in the led lights also, trying to sell my 99 LTZ, and the radio lights are out.
Do you have the #'s for the bulbs? Did the dealer stock the bulb??
Thanks!
Paul
RHoschett
02-06-2006, 09:11 AM
I got the radio LED's from here > http://www.corvetteradios.com/Page7.html
Search if you want but this was the ONLY place I was able to find that would sell me bulbs.. $2.00 each, you need 10, $2.00 shipping..replace them ALL you dont want to do this again! Its easy enough to remove the radio and front bezel..you need to be a decent solder tech to replace the bulbs, yes they are soldered in! IT fixed me up great!
