Page updated on 04-20-2018
03 Explorer EB How to Disable factory alarm?
yamahonda41
01-03-2006, 09:50 AM
Hi,
I bought a used 2003 Exporer Eddie Bauer with I believe a factory alarm/siren. It automatically arms itself after about 1 minute and then alarms if you bump it or if you are working under the hood, etc. It is driving us crazy.
I cant find a way in the owners manual to disable it. When I went to look at it from the previous owner I did not even know it had an alarm so he must have had it turned off somehow.
Any help greatly appreciated.
Thanks!
nmikmik
08-14-2006, 03:28 PM
did you ever find how to do it, my buddy have the same problem :(
Kobaltic
08-26-2006, 01:58 PM
Here is the wiring diagram for this model. Hope this helps. IF not post on www.the12volt.com
12volts yellow + ignition harness
Starter red + ignition harness
Second Starter N/A
Ignition red/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory green/lt. green + ignition harness
Second Accessory N/A
Keysense black/lt. green + ignition harness
Power Lock pink/yellow - driver kick panel or CSM
Notes: The CSM (Central Security Module) is below the passenger side C pillar.
Power Unlock pink/lt. green - driver kick panel or CSM
Notes: The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake up the system refer to directfax document #1094.
Lock Motor pink/black 5wi driver kick panel or CSM
Unlock Motor red/orange 5wi driver kick panel or CSM
Parking Lights+ brown + headlight sw or driver kick
Parking Lights- N/A
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light black/pink + electronic day/night mirror
Door Trigger black/lt. blue + driver kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin common with doors
Hood Pin
Trunk/Hatch Release org/lt. grn or pur/yel + Central Security Module
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm green/purple - driver dr harness or CSM
Disarm No Unlock see factory alarm disarm
Tachometer NOT white/lt. blue ac ignition coi or coil pack
Wait to start N/A
Brake Wire tan/red to lt. green + brake pedal switch
Parking Brake
Horn Trigger yellow/lt grn or yellow/lt blu - steering column or CSM
Memory Seat 1 brown/lt. green + driver seat mod under seat
Memory Seat 2 black/orange + driver seat mod under seat
Memory Seat 3 +
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Alternate Part3 #: 556UW
Alternate Part4 #: 555U
Notes:
