overdrive ?k.leape 01-02-2006, 01:05 PM I have a 02 Xterra with a 5 speed. it gets about 14 mpg on the highway and the motor is screemin on the highway. are there any after market or stock overdrive set ups for me??? OffroadX 01-02-2006, 01:15 PM It has an overdrive, 5th gear is .811:1 Much taller and there won't be enough power to use in the first place. You could get larger tires, that would lower your overall ratio, but your indicated speed-to-RPM correlation will not change. Indicated 70 will still turn 3300 RPM (or whatnot) but you'll actually be doing 75 or so. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
