how to program keyless entry corolla 2005mohemmee 12-29-2005, 10:25 PM help me how to program the original keyless remote for corolla 2005 I got the original remote from toyota Thankyou Tim04LE 01-25-2006, 01:00 PM help me how to program the original keyless remote for corolla 2005 I got the original remote from toyota ThankyouYou can try the procedure listed at this link; http://www.geocities.com/toyota_speed2003/keyless_entry.html it worked on my 04............:grinyes: Onblsht 02-06-2006, 08:13 AM What is the FCC number of your remote? Breadman 03-31-2006, 11:47 AM The FCC# is GQ43VT14T........................Thank You. PS I will try the program in the mean time. Onblsht 03-31-2006, 01:46 PM This should be it for your 05 Corolla: 1. Start with the following conditions: You are in the drivers seat. a. Key is out of the ignition b. Driver door is open (all other doors closed) c. Driver door is unlocked (other doors don't matter) 2. Insert and remove the key from the ignition twice within 5 seconds. 3. Close and open the drivers door twice within 40 seconds. 4. Insert the key into the ignition and remove it. 5. Close and open the drivers door twice within 40 seconds. 6. Insert the key into the ignition. 7. Close the door 8. Turn the key in the ignition on and then off. 9. Remove the key from the ignition. 10. The power locks should automatically cycle once to indicate that you have successfully entered program mode. 11. Within 40 seconds of the entering program mode. a. press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds. b. within 3 seconds, press the transmitter lock button for more than 1 second and release. c. If the transmitter has been sucessfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted. d. If multiple remotes are to be programmed, repeat steps A-C. 12. Open the driver's door. Breadman 03-31-2006, 02:06 PM Thanks Chris I just tryed this and could not get it to work. Where would i look to see if the car has this keyless system....Thanks Breadman 03-31-2006, 03:53 PM OK......I called Toyota and asked where to look to see if i had the keyless system or not. They asked for the vin. # and looked it up. My car doesn't have it. All the remotes in the world want open this baby.... Thanks for all the help Breadman:screwy: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
