Cruise Control problem in 98 Camaryzrahul 12-29-2005, 09:20 PM Hi , I am new to this forum and would appreciate if i can get some advice on the problme i am facing while driving my 98 Camary ( LE ) . Problem description -------------------- When i switch on the cruise control and push the lever down to set the speed , the crusie speed is set for a couple of seconds. And then the Crusie light on the dash board starts blinking and the cruise drops off ( speed drops ) off making me use the gas pedal again . Would apprecite if any one could help me resolve this. Regards Rahul :) Brian R. 12-30-2005, 01:40 AM Welcome to the AF! See if you have trouble codes by shorting terminals Tc and E1 of the DLC2 connector (by driver's left kick panel under dash). Cruise indicator light should blink with trouble codes. zrahul 12-30-2005, 12:09 PM Brian , Thq, let me try this and get back on this Regards Rahul Welcome to the AF! See if you have trouble codes by shorting terminals Tc and E1 of the DLC2 connector (by driver's left kick panel under dash). Cruise indicator light should blink with trouble codes. zrahul 01-02-2006, 07:11 PM Hi All, Thq to the Forum, I was able to fix the Crusie Control Problem based on the similar problems/suggestions posted in this fourm. The missing link was the Connector which was dangling next to the Control actuator, Once connected Crusie control started working fine. Brian , Thq, let me try this and get back on this Regards Rahul vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
