87 civi si Bogs on accelreation, eventually will stall
loujoan
12-29-2005, 10:35 AM
Hi,
I've replaced the map sensor,fuel filter,fuel pump,mfir, and oxygen sensor. The pgmfi light is on. It starts and idles rough,.When it warms a little, it bogs on acceleration, then eventually stalls. Any help would be appreciated. Thanks, Lou
mrlindeman
12-29-2005, 06:39 PM
I just got it fixed. I actually replaced the same things you did and couldnt figure it out. Turns out i had the timing retarded by a tooth. It made a huge difference. I got alot of help by posting here though too. Thanks guys. Ever since i put the new cam in it ran like poop. Took me 2 weeks of trouble shooting to fix it. As for the rough starting i couldnt fix that. Its just something i have to live with since i de-vacumed the car. It has no cold idle. If you have any questions let us know. I would def check the timing though. Good luck.
Bud. :smokin:
loujoan
12-29-2005, 07:38 PM
Bud. :smokin:
Bud,
Thanks for your input! This just started, it was running fine.I will check the timing but I don't think that is it. Thanks again, Lou
lxndr
12-30-2005, 12:19 AM
Have you checked the ECU code? When the PGMFI light is on that means the ECU is throwing a code. The number of LED flashes will tell you what the problem is.
Here's a link:
http://www.automotiveforums.com/vbulletin/showthread.php?t=236249
loujoan
12-30-2005, 01:38 PM
Here's a link:
Thanks for your input! I didn't have any lights on the computer! It ended up being the 20 amp fuse for the ecu didn't have a good contact. Runs fine again but the pgm-fi light still goes on under acceleration. I also have 1 and 2 light on. I replaced the map sensor a short time ago.? Runs good!!!? Thanks for the link.
loujoan
12-30-2005, 02:14 PM
Bud,
Bud,
It was the 20 amp fuse for the ecu. Bad contact!!!!! Can you believe it?! Runs fine now. What ever happened to spark and gas???!!!!!!!!! Later, Lou
