engine just stoppedbsnovelties2001 12-28-2005, 07:04 PM This has happened to me twice, going do the road the engine just shuts off, the first after 3 days of changing this and that from advice from a chev dealership, it turned out to be the coil wire, even thro the plugs was firing using a timing light, this time again everthing I have checked coil wire, coil, sencer underneath in frt, also I had a motorest that was behind me noticed just before the engine stopped, saw sparks coming from underneath the engine, but I don,t see anything wrong????????????????????? maxwedge 12-28-2005, 07:15 PM And this is what year? bsnovelties2001 12-28-2005, 07:20 PM 99 vortex v6 maxwedge 12-28-2005, 07:52 PM Well do you have spark now? Does it crank over? Look for a bad rotor if no spark then scan it and see if you have cranking rpms bsnovelties2001 12-28-2005, 08:00 PM the only thing I've done on it is checked the coil wire(on the omhs meter) it cranks over, just won't fire .will just the rotor in the morning. can't do anything else tomorrow (snow/freezing rain) I'll just play in the garage.... mountie1982 12-29-2005, 05:09 AM the only thing I've done on it is checked the coil wire(on the omhs meter) it cranks over, just won't fire .will just the rotor in the morning. can't do anything else tomorrow (snow/freezing rain) I'll just play in the garage.... Read this http://www.automotiveforums.com/vbulletin/showthread.php?t=491395 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
