reverse humming
jdq
12-28-2005, 10:19 AM
When I put car in reverse after starting I get a loud humming noise ,seems to go away after warming up,what could this be.Also is it difficult to change serpentine belt,any tips.thanks
wafrederick
12-28-2005, 04:22 PM
It sounds like the carrier bearings are bad in the rear end.Yes, it is a common problem and replace ALL the bearings and seals.You do not want to do it twice.
WPAGEJR
12-29-2005, 10:29 AM
HAS SOMETHING TO DO WITH YOUR PUMP IN THE TRANMISSION. CHECK PREVIOUS THREADS IN REGARDS TO THIS. DODGE ALSO PUT OUT A TSB FOR THIS PROBLEM.
jdq
12-30-2005, 08:05 PM
Can you be more specific I couldnt find tsb.thanks
WPAGEJR
01-03-2006, 09:21 AM
HERE IS THE LINK TO THE TSB. http://dodgeram.info/tsb/1999/21-08-99.htm
jdq
01-04-2006, 01:34 PM
Thank you
jdq
01-04-2006, 06:03 PM
Any help with serpentine belt ,thanks
jdq
01-05-2006, 05:37 PM
Nevermind its pretty straight forward , easy enough
