DTC's on 95 tahoe
Google
Web AF
AL52818
12-27-2005, 04:55 PM
I just used the paper clip trick to extract DTC's for my 95 Chevy Tahoe. Can anyone tell me how to read the following flash sequence: 1 short, 1 long, 2 shorts. Is this DTC 13 ? Any help greatly appreciated.
rb1
12-31-2005, 06:11 PM
to read DTC's the ECM will flash a 12 3 times before any codes will flash. Usually 1 short followed by 2 short flashes.
AL52818
01-02-2006, 07:09 PM
RB Thanks for the reply. Should have included in my original post tthat I do get the initial DTC 12 first, then this is followed by the 1 short, 1 long, then 2 shorts that I described originally.
ratinfested
01-03-2006, 03:39 PM
If the 1-long was a pause then you have 12 all over again which means there are no codes stored.
2000CAYukon
01-03-2006, 05:58 PM
Actually, if the 1-long is a pause, it could be Code 21. I went out to my truck at lunch time and set code 42 by disconnecting the EST wire. After juming pins A and B I got:
flash, pause, flash, flash, long pause (Code 12),
flash, flash, flash, flash, pause, flash, flash, long pause (Code 42),
Code 42 repeated.
After the long pause will be the first digit, then a short pause, and then the last digit.
//2000CAYukon
Google
Web AF
