96+ Water Pump Replacement
Google
Web AF
blazee
12-27-2005, 01:21 AM
This "how to" covers removal and installation of a water pump on 96+ vehicles with the 4.3L V6 Vin "W". Some of you may recognize this procedure, because I've posted it several times. Thanks to DevilMan13xx for taking pics to add to it, I believe that it is now threadworthy.
1)Drain the coolant:
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set1_06.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set2_01.jpg
2)Remove the shroud:
7-10 mm bolts
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set2_02.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set3_01.jpg
the other 3 are on top in the front, cant miss em
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_19.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set4_03.jpg
no shroud
3)Remove the fan and clutch:
There is no need to separate the fan from the clutch. The whole thing threads on to the end of the water pump. I don't know the size, because rather than break out all my wrenches, I just grabbed an 18 inch crescent wrench. Place the wrench on the nut and tap loose with a hammer. the tapping will break it loose. You have to tap it, if you just try to loosen it, the belt won't hold it and the whole thing will turn. After it breaks loose just spin it off.
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set5_02.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set6_01.jpg
no fan or clutch
4)Break loose the bolts holding the pulley on:
4- 13 mm or 1/2" bolts
Just break them loose, don't remove them
5) Remove the serpentine belt
6) Remove the pulley:
Finish removing the bolts holding the pulley and remove the pulley
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set9_01.jpg
7) Disconnect the hoses
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set10_02.jpg
MAKE SURE YOU HOLD ONTO THE PLIERS!
8) Remove the old pump:
4-14 mm or 9/16" bolts
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set12_01.jpg
9) Clean the surface:
Remove all traces of the old gasket.
It would be a good idea to flush out the block and heater core while you're at it.
blazee
10) Install new pump:
Apply a bead of blue Permatex around the holes on both sides of the gaskets, put them on the pump and insert the bolts through the holes to hold the gaskets in place. Carefully lower the pump in to position. Thread the bolts into the block and snug them. Then remove the bolts one at a time, add the permatex to the threads, and then reinsert. (only do one at a time so that the pump doesn't shift and disturb the mating surfaces) Then tighten all the bolts.
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_04.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_02.jpg
11) Reinstall everything in reverse.
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_11.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_14.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_16.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set13_17.jpg
There will be a lot of air trapped in the system, so after you fill it, get the engine to operating temperature, shut it off, let it cool, then add more. The air trapped in the system can cause your engine to over heat if left unattended.
I suggest filling the system with water only and run it like that for a day or two just to make sure there are no leaks. That way you don't waste your antifreeze if you have to do further repairs.
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set14_01.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set14_02.jpg
http://i140.photobucket.com/albums/r10/blazeepics/Water%20pump%20thread/Set15_01.jpg
and your done.. should look simliar to this with no left over parts
rlith
12-27-2005, 06:23 AM
Looks great blazee.... Gonna link this off the how-to links on my site...:)
billibong
12-27-2005, 11:57 AM
Excellent post Blazee. Love the pictures, makes it soo much easier to understand what is going on.
DINO55
12-27-2005, 12:14 PM
Blazee, You make it look soooooo easy........
excellent post as usual....
:ylsuper:
blazee
12-27-2005, 01:24 PM
Thanks for the kind words, guys. :)
laxman21
12-27-2005, 06:18 PM
Nice post.
I couldn't get the fan clutch off mine. The shop said he used an air chisel with a flat bit to start the nut off.
rlith
12-27-2005, 08:44 PM
Nice post.
For the 96+ you can use the ford fan clutch removal tool from any loan-a-tool (advance, autozone, pepboys, etc.) makes life easier for them.
laxman21
12-27-2005, 11:25 PM
Live and learn.
BTW, I was leaving for VA beach the next morning. I called a few places down there and they beat the labor install price by $100 compared to anyone local, I already had the parts. So I loaded up on antifreeze and drove down, was just a small leak anyways.
CEO Wrench
01-08-2006, 05:56 PM
Blazee, this is excellent! One other tip I would add is to place a piece of cardboard or something between the fan the radiator as you are disassembling it; I ruined my radiator when the fan accidentally slipped and gouged one of the core tubes.
blazee
01-08-2006, 08:08 PM
Thanks, that's a good tip.
FantasticChadwick
01-28-2006, 12:31 PM
Wow! Great advice and instruction! I have been postponing replacement of my waterpump for about a year now....maybe this will give me the jump I need!
Does the thermostat play at all into this procedure? If not, do any of you all know where in the system I can find the thermostat? And do you know if there are any other standard parts that I'm going to need when replacing it?
Also, when replacing the waterpump.....Do you use both paper gaskets that come with the waterpump AND gasket seal?
Chadwick
rlith
01-28-2006, 08:33 PM
Chadwick
Follow your upper rad hose to the engine intake. Inside that housing is your thermostat.
Yes, use both gaskets (1 each side) and you can use a little rtv to hold them in place while you mount the pump.
Rick1488
01-30-2006, 12:18 AM
Hey folks don't forget to thank DevilMan13xx for the great pictures!!
Thanks,DevilMan13xx
FantasticChadwick
02-05-2006, 08:45 PM
Thanks to everyone who put in advice on this page I replaced both my waterpump and my thermostat sans incident today during the Superbowl!
Thank you all!
Chadwick
gman2153
02-19-2006, 04:17 AM
That was a great string of informative pictures..
Even a non-mechanic type like me can easily follow it..
Thanks for the bloody hand pic, I can truly relate to that... LOL
Good Job.... Thanks.
Fred Klintworth
08-01-2006, 03:03 AM
I used this yesterday to replace the water pump on my son's 1998 Blazer, and first of all I want to thank Blaze for writing this, and the person who supplied the photos. Great job guys!
I'd like to add a couple of comments in the interest of helping others:
1) I wasted a lot of time trying to loosen the large nut holding the fan. I actually rented a took kit at AutoZone (Advance didn't have it); but it didn't work -- wrong sizes I guess, I never figured out how it worked. Anyway, the way I got it loose was to put additional tension on the belt, and repeatedly whacking the adjustable wrench until it came loose. To get the extra tension on the belt I put a 3/8" socket wrench head (the square part) into a square hole in the belt tensioner (left side of engine when viewed from front, below alternator), and had my son pull up on the socket wrench while I whacked the side of the adjustable wrench repeatedly. It didn't come loose easy -- took about 10 really hard whacks.
2) If you're going to use an adjustable wrench to loosen the big fan nut, you have to have a big one. I had to use my biggest one.
3) Don't make the mistake I did and try to put tension on the belt by putting a socket on the nut holding the belt tensioner. You don't use a socket at all. You insert the square head of the socket wrench into the pre-cut square hole in the tensioner.
4) I didn't use the radiator drain plug to drain the radiator. It had a special head I couldn't turn by hand, and I was affraid I'd ruin it if I turned it with a flat-head screw driver. I just drained the fluid by removing the water pump.
5) There is a large hose that connects to the water pump that is not shown in these pictures. It's on the bottom left. No big deal to remove it too.
6) Aligning the new pump in order to insert the 4 bolts is awkward. To facilitate alignment, I put a couple of smaller screws in the two top holes of the pump, and inserted them into the engine holes to temporarily hold the pump in place while I screwed in the two bottom bolts.
7) We went ahead and replaced both the thermostat and the serpentine belt too. The thermostat is held in place by two nuts at the front center of the engine. I bought a gasket for it separately, but didn't need it, since the thermostat's rubber outer ring is in fact the gasket.
8) Advance sells a small pouch of blue RTV for 98 cents which is ideal for this. I used it on both sides of the two gaskets for the water pump. I didn't use any RTV for the thermostat, and it didn't leak.
Hope this helps you.
CanvasBack@triton.
11-19-2006, 11:26 PM
Nice post.
[quote=CanvasBack] Very helpful.
I had some trouble with the fan clutch also...but by using your 3/8 ratchet to APPLY tension to the belt, it held just enough to allow the nut to pop loose.
mwaldrp
05-22-2007, 01:37 AM
Rather than using a long wrench and tapping it to remove the fan and fan clutch, a simpler way is to use the wrench on the fan nut and a socket wrench with a 24 mm socket on the alternator nut. Turn the two tools in opposite directions. This allows you to use friciton from the serpintine belt to make loosening the fan nut a bit easier. Doing it this way, I had the fan nut loosened and the fan/clutch assembly removed in a matter of minutes with very little trouble.
Bob E
01-04-2008, 12:47 PM
Is this pretty much the same if you have an X in the vin #. The pump looks different.
Bob E
01-04-2008, 12:54 PM
sounds like your pump is differnt. you must have a vin# with an X in it.
nickdaytona
01-30-2008, 02:59 PM
my fan clutch was a bitch as well, but I found a strange and effective way to get it off. On the front of the A/C compressor bracket there is a threaded hole which I put in a 3" bolt. I then put a 10mm wrench onto one of the water pump pulley bolts ( at approx 5 O'clock positon) and rotated the fan until the top of the 10 mm wrench notched onto the 3 " bolt, thereby locking it. fan nut came loose no problem after that. Gear wrench's are better for this as they are a little longer than the short 10 mm wrenches you get in the tool sets.
cbec1999
02-01-2008, 06:30 PM
I got a few pics from the pump swap I did today.
Where is the upload attachment prompt???
rockinpr
04-30-2008, 07:51 PM
great instructions great pix just finished my pump installation ,if I may add one tip though its to use a couple of studs (bolts with no heads) in the block to slide the pump on so its easyer to line the pump up (it was kind of hard to see the bolt hole on my 97 with everything in the way) a couple long screwdriver would probaly do.
FantasticChadwick
04-30-2008, 09:06 PM
Sounds like a great idea! That would indeed make the installation a lot easier and take a lot of the guess work out of it!
Chadwick
Xcrewchief
04-30-2009, 09:53 PM
This is what worked for me to loosen the fan nut : Use a 13 mm box wrench on the pulley bolt and lay the other end up on the tensioner pivot point. Then when you try to loosen the nut with whatever wrench you use (I used a big pair of channel locks), you loosen it while the tension on the wrench holds it in place.
For reinstall, I used an adjustable rubber filter wrench (an old one that I had in my 'Just-in-Case-I-Need-It' box to put tension on the pulley.
Great post and keep talkin', guys!
jborim
07-21-2009, 10:04 AM
Great explanation and illustration Blazee. You saved me 400 bucks! Thank you!
wafrederick
07-21-2009, 10:35 AM
There is one place those special fan clutch wrenches can go go,in the garbage can!They are too thin and can break very easily.I use an air hammer with with a long chisel bit which works better.This method requires with the belt still on putting the bit on the end of the flat of the nut.
Google
Web AF
