1994 chev.cav.electical problem
Google
Web AF
Anton25
12-26-2005, 11:05 PM
When I put the signal turn my signal light is all the time on and does not blink. I am curious where is located the signal turn flasher and how does it look
Thanks
Fr33ze
01-01-2006, 10:51 PM
Thanks
Does it do it on both sides?
If one bulb is blown, it wont blink on the side its blown, but it will on the other.
As for the signal relay, its under the drivers side dash, above the brake pedel, in the fuse panel, its round and its glass or clear plastic. Pull it to remove.
89Sunbird
01-02-2006, 03:13 AM
No, if one bulb is blown, the other will just flash twice as fast.
100% sure it is your relay. Get a 512 turn signal relay from Autozone or whatever, and it'll be right next to your center console, on the driver's side, inside the lower panel you have to remove (like 4 or 5 screws)...
Fr33ze, where have you seen the relay in the fuse box? I only know of 2 locations for em...the one I mentioned and on the floor, up against the firewall, behind the clutch pedal...
Fr33ze
01-02-2006, 12:22 PM
Maby on a later model, but on my 94 it just says on.
Same answer, in MY 94 its above my left foot, atached to the underside of my dash. On the newer cavs there on the firewall...
Google
Web AF
