car died---hard to re-start--code P0506batmobile78m 12-26-2005, 04:28 PM 180,000 mi. 1997 Has original battery and alternator (amazing) and when it died it was in gear when i just pulled up to a light. Lights were doing strange things so i first thought alternator. Tested it and it doesn't seem to be getting much of a charge to the battery, if any. I was all ready to re-place both and then i noticed the check engine light on. Code reader said P0506 (idle control system-low idle). Could a bad alternator-battery produce the low idle code? Or do I have a different problem than I thought? Thanks. quake61 12-27-2005, 02:56 PM 180,000 mi. 1997 Has original battery and alternator (amazing) and when it died it was in gear when i just pulled up to a light. Lights were doing strange things so i first thought alternator. Tested it and it doesn't seem to be getting much of a charge to the battery, if any. I was all ready to re-place both and then i noticed the check engine light on. Code reader said P0506 (idle control system-low idle). Could a bad alternator-battery produce the low idle code? Or do I have a different problem than I thought? Thanks. code 0506 means idle control system RPM lower than expected check in battery and alternator separately it could be because if is no charge or low charge sparks is getting lower power resulting in bad explosion on pistons batmobile78m 12-30-2005, 09:06 PM Replaced alternator, plugs and wires, PCV valve. Battery OK. Gave up and took it in. Idle air control valve was bad. Ironically, i almost replaced it myself. DAMN IT! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
