welded diff.greyrealsteam 12-25-2005, 11:42 PM i talked to people and read up on this. i couldnt find a thread on this so........ what are the advantages of a welded diff, i know that one is its cheaper than buying a posi rear end, and you have full lock all ttime, i know that the downside is that you might break axles, not while racing or driving hard or anything, but when makin a u turn in a parking lot or everyday driving. what are the steps in welding your diff. !? 666_speed 12-26-2005, 12:07 AM welded ones keep it locked which makes turning in rain/snow horrible....i had it done to the iroc i had and it really freaking sucked...i can really see no advantages imo MagicRat 12-26-2005, 12:31 AM greyrealsteam 12-26-2005, 01:18 AM thanks! i live in so cal, so i dont gotta worry bout the rain that much, and snow is out of the question :P i was looking at mods that i could do so i can drift my car. but i think ill only do that if i had 2 cars, i dunno if sounds smart to do to my daily driver. RahX 12-26-2005, 04:13 PM i wouldnt do it to your daily driver. the inside tire will always skip and hop and scuff and cause you problems on turns. i would recommend a gear locker assembly for your daily driver. it locks the diff going straight and unlocks so you can turn. or you can get a minispool which locks the diff permanently but is easily removed if you want to go back to your open diff. greyrealsteam 12-26-2005, 11:38 PM hmm, where would those accessories be found? ebay? bag91 12-27-2005, 01:00 AM hmm, where would those accessories be found? ebay? Where in So Cal...I live in Nor cal? RahX 12-27-2005, 02:13 AM you can look on ebay. powertrax makes a lock-rite unit that is pretty good. summit or jegs might be a place to look too. http://store.summitracing.com/default.asp?Ntt=powertrx&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115&target=egnsearch.asp greyrealsteam 12-27-2005, 09:18 PM i live in LA area, eric39232 12-28-2005, 04:47 AM if u race a whole lot then locking it would be a positive is u spin tires alot. we did it to my grandfathers truck so he wont get stuck in his field and it works great till u take off in wet weather then u end up going sideways down the road till the tire hook up but id say do it if u race alot greyrealsteam 12-28-2005, 11:41 PM maybe ill just go to the junk yard and buy a rear end and do it! and keep my stock one at home until im done with that, or break the welded one. Elk 01-07-2006, 09:58 PM maybe ill just go to the junk yard and buy a rear end and do it! and keep my stock one at home until im done with that, or break the welded one. Get a Mini Spool will be cheaper and easer to install. This should be the right one for your car: Mini Spool on Ebay (http://cgi.ebay.com/ebaymotors/NEW-GM-7-5-7-625-10-BOLT-26-SPLINE-MINI-SPOOL_W0QQitemZ8027775965QQcategoryZ33731QQrdZ1QQc mdZViewItem) It only takes about 30 minutes install or remove so you can take it out when you don’t need it and it will make fixing your car a lot easer if you do brake an axle. Also I have to ask do you have a welder or someone that’s going to weld it for you for free? Because if your planing to pay someone to weld your diff if would probably be cheaper to buy a Mini Spool. A Mini Spool will give you full-lock just like a welded diff without all the downsides and work. The only reason I would weld the diff of a car is if I was going to run it in a demolition derby. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
