my 350
Google
Web AF
blownz28
12-25-2005, 11:27 PM
hey guys
while my heads are in the shop i thought i would give you
the run down on my engine,to hear your ideas!
1973 4 bolt main 010 block .060 over and o ringed
eagle h beam rods stock throw
eagle crank
je blower pistons 8.5 cr
world product sportsman heads 64 c.c 200 cc intake
the heads are getting a 3 angle valve job, decked
and the seats cut for larger springs
the cam is a comp cam .487/.501 lift 230/244 at .050 113 C.L
this is the cam the machinest recemened
with a weiand 6-71 supercharger and two 650 double pumpers
the machinest said i would make around 750 hp
and a th350 tranny going into a 1981 Z28
what to you guys think???
http://img288.imageshack.us/img288/8216/mystuff0089jd.th.jpg (http://img288.imageshack.us/my.php?image=mystuff0089jd.jpg)
demon9766
01-06-2006, 12:54 AM
sounds like your motor is going to be pretty hot good luck. oh and if you don't like the cam u got try a comp cams nitrous cam they do really good with blowers.
wrightz28
01-18-2006, 01:44 PM
good lord, you'll shoot your eye out kid.
sure the car is up for the stress?
jveik
02-13-2006, 09:57 AM
just a question, you sed its a 6-71 blower? im confused can somebody fill me in on the numbers? i thought the numbers were (#cylinders-Combustion chamber volume) like 8-64? is it some other deal or something?
Mines69Olds
02-13-2006, 06:52 PM
You need to get some pics of it in the car when you are done. By the way what kind of car are you going to put that bad boy in?
blownz28
02-14-2006, 12:19 AM
its going in a 1981 chevy camaro z28
like this one
http://img117.imageshack.us/img117/9108/blownz18uc.th.jpg (http://img117.imageshack.us/my.php?image=blownz18uc.jpg)
mine is white with blue stripes and t-tops
drvngstorm05
02-14-2006, 02:37 AM
Holy Massive Blower Batman!!!
FireFox05
02-14-2006, 03:48 PM
^I second your thoughts^
97cavalier
02-14-2006, 06:52 PM
cool, my dad used to have a 80 camaro.
Mines69Olds
02-15-2006, 09:39 AM
Tell us about the car as well. I mean is it auto or stick, what kind of rear end you putting in? Your guess on the 1/4 mi???
blownz28
02-17-2006, 08:38 PM
as of right now the z is sitting in my driveway waiting to slide
into the garage. I'am the fourth owner as per carfax. I bought the
Z-28 in 2003 with a blown engine (as in dead) the car is white with blue
stripes and dark blue interor i replaced the front sub frame, engine
and tranny in one shot. I wish i had a digi camera back then
http://img136.imageshack.us/img136/2946/mystuff0047io.th.jpg (http://img136.imageshack.us/my.php?image=mystuff0047io.jpg)
i bought the new th-350 from summit racing and has held up great
now with the blower motor i will swap the th350 for a th400
i have a 10 bolt rear with 4.11's in but i am going to put 355's or
373s in
97cavalier
02-17-2006, 09:04 PM
put 3.73's in they are a good all around gear.
blownz2886
03-01-2006, 06:48 PM
373s in
I have a 671 on an 86 z-28 w/ a 383 stroker. Rolller cam, 010 block,o-ringed, blueprinted on a v-30 rmc cnc machining center. When you get yours done HOLD ONE!! Check out www.performancecncblocks.com (http://www.performancecncblocks.com). You can't beat his prices or quality of work. I'll post a picture as soon as I figure out how.
blownz2886
03-07-2006, 09:40 PM
Heres my 86 Z-28, 383,671 Dyers street chargerhttp://i43.photobucket.com/albums/e391/Theresa5399/camaropics012.jpg
97cavalier
03-07-2006, 09:42 PM
wow, that thing is bad, but with t-tops, i would reinforce the frame if you did not do it already.
blownz2886
03-07-2006, 10:06 PM
Has subfram connecters, 3.73 gears,Auburn posi, Art Carr 700r4 Tran.http://i43.photobucket.com/albums/e391/Theresa5399/camaropics011.jpg
Google
Web AF
