Fuel pump quit
Google
Web AF
riccbhard
12-24-2005, 01:55 PM
98 Blazer - 4x4
Go out this morning to start it, and it turns over but will not run.
Turned the key to Run but didnt start it, and I no longer hear the priming of the fuel pump.
Anyone think that it is the fuel pump? Or could it be something else?
billibong
12-24-2005, 01:58 PM
Did you check any relays or fuses?
Probably the pump, how many miles on it??
MT-2500
12-24-2005, 02:35 PM
Got spark to plugs?
Got 12 volts power to fuel pump or the fuel pump prime test plug.
Check for them two things first and post back answer.
MT
drewgibs
12-24-2005, 02:47 PM
Got spark to plugs?
MT
hey im kinda dealing with the same problem, where do i find the fuel pump prime test plug?
MT-2500
12-24-2005, 03:03 PM
Drewgibs
Your Blaizer is a different year.
Would be better to start a new post.
Two different problems on one post will get 2 or more confusing answers.
Start a new post and give year make and model and engine and trans and mileage and also if you have spark to plugs.
MT
MT
riccbhard
12-24-2005, 06:01 PM
Where are any possible relays/fuses for the fuel pump on our '98?
EDIT: Found the relay. Could it possibly be bad?
EDIT #2: The fuel pump was replaced right before we got the Blazer and there was a part they forgot in the pump and caused it to always make a whirring/buzzing noise.
MT-2500
12-24-2005, 07:20 PM
First thing is to check for spark at 2 or more spark plugs.
If good spark .
Check the ECM B 20 amp fuse.
Then go to this link for a pdf on it.
http://members.troublecodes.net/crunch/98blazfuelpr.pdf
rlith
12-25-2005, 07:42 AM
Our fuel pumps whine naturally...
riccbhard
01-15-2006, 04:04 PM
It was the fuel pump. Glad that was fixed. It was getting hard for us to haul things home from the store in the '89 Camaro.
MT-2500
01-15-2006, 04:48 PM
Thanks for posting back the fix. Glad you got it going.
To help others that may have that problem How did you figure out it was the fuel pump?
MT
Google
Web AF
