no heat in cabin, 93 pa. engine running hot
cort71
12-18-2005, 08:44 PM
:sly: well now that its twenty degrees outside i have no heat. i think it could be the heater core maybe or the thermostat... after the engine is warm she will kick out a little bit of heat for about thirty seconds then its time to freeze and the engine is running hot. im needing to know from you all if i am in for a a simple job or am i screwed and gonna have to spend the money to get the heater core replaced. :uhoh:
HotZ28
12-18-2005, 09:31 PM
Well, one thing for sure, if it is 20 deg outside and your engine is running hot, you have a bad (closed) thermostat or another circulation problem!!
cort71
12-20-2005, 02:43 PM
thanks HotZ28... it was the stat.. a ten dollar fix and i getting that warm all over feeling,,, thanks bunches.
