4wd Question
Google
Web AF
unbe
12-18-2005, 06:11 PM
My 98 S-10 goes into 4 lo & 4hi ok but when in 4hi the indicator light doesnt come on .Any advice would be appreciated.
movin2stereo
12-18-2005, 10:22 PM
How do you know if it is in 4hi?
unbe
12-19-2005, 04:12 PM
In snow the front tires are biting but I can tell by the speed Im not in 4lo
rlith
12-19-2005, 07:55 PM
This has been covered a million times...:)
1st Check vac actuator under battery tray for tears, or leaks, and that the vac hose is connected. Replace if found
2nd Check vac hose leading from vac actuator to vac switch on transfer case for cracks and dry rot. Replace if found.
3rd Check remaining 2 hoses from vac switch on transfer case for dryrot or cracks Replace if found.
If all of the above are fine, disconnect your negative battery cable for 1/2 hour then reconnect it. If your 4x4 works after that you probably have a failing TCCM (Transfer case control module)
If that doesn't solve it, it's most likely the encoder motor.
unbe
12-19-2005, 08:09 PM
Thanks alot Rlith for your response.
rlith
12-19-2005, 08:14 PM
No prob, let us know how it turns out.
BlackZR5
12-20-2005, 12:48 PM
Does anyone think that this would be an odd problem for a 2002 ZR5?
It just started this week, and I accused my wife of breaking it.
Shortly thereafter my Service Engine soon light came on and the
AutoZone guys said it was a coolant temperature not in sink with the thermostadt temp. Does anyone think they are related?
Awesome forum
MT-2500
12-20-2005, 01:00 PM
Unbe.
If a 233 transfer case with shift buttons on dash.
Ground pin 13 on diagnosic connector and read codes.
Post back any codes you may have.
MT
MT-2500
12-20-2005, 01:03 PM
BlackZR5 ^^^
Welcome to AF
But you have posted on a S-10 4 wheel post.
Start a new post in ZR5 forum.
Good luck MT
herkyhawki
12-20-2005, 01:37 PM
Check the light bulb in the 4HI button. Pry the button assy out of dash, twist to remove bulb.
BlackZR5
12-20-2005, 03:05 PM
BlackZR5 ^^^
Welcome to AF
Good luck MT
Hey MT, I am completely blind. I do not see a forum for the 4 door S-10 with the ZR5 package. Could you post a url maybe?
Thanks,
MT-2500
12-20-2005, 04:09 PM
BlackZR5
You are in the right forum if it is a chev S-10.
A ZR5 could cover a lot of things or even could be a Honda or anything/.
But you need to start your own new post/tread on it.
And give the eng and trans and code no and all of the info you you have and some one will help you.
Posting in on another post gets everyone confused.
Start a new post please.
MT
BlackZR5
12-20-2005, 07:13 PM
BlackZR5
MT
MT,
Thanks for the tips!
Merry Christmas!
Google
Web AF
