abs Brake light onotiee 12-17-2005, 09:30 AM 2001 S10 pickup 4.3L the abs light came on and now stays on after every startup. Talked to dealer and was told the problem can only be A faulty brake computer @$1000.Suggested fix was put A piece of black tape over the light if I did not want spend the $1000. Is there any other possible problem besides the computer that would cause the ABS light to stay on? RahX 12-17-2005, 04:59 PM you need to get someone to pull a code so we can tell you what you need to do. it could be anything at this point not just a faulty ebcm. dmbrisket 51 12-17-2005, 05:17 PM a solid light means a hard failure, the system checks detects something wrong and shuts the abs down, code needs pulled, and a faulty ebcm will not have a code otiee 12-22-2005, 07:56 PM 2001 S10 pickup 4.3L the abs light came on and now stays on after every startup. Talked to dealer and was told the problem can only be A faulty brake computer @$1000.Suggested fix was put A piece of black tape over the light if I did not want spend the $1000. Is there any other possible problem besides the computer that would cause the ABS light to stay on? Thanks for the help! Will get back after we try to get A code pulled. First atempt @ advanced auto parts failed They only check emission codes.Hate to go to local chevy dealer$ vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
