Safari 1999 Outside air temperature sensor.
Google
Web AF
ypelchat
12-15-2005, 08:35 PM
Hello guys;
I just bought a 1999 Safari SLE AWD, and the temperature sensor indicates OC. This probably means that the sensor is bad or the connection is dirty or corroded. I would like to know where this sensor is located? It's probably near the frot of the radiator, but where exactly should I look to find it?
Thanks.
Yves.
old_master
12-31-2005, 11:22 PM
Not exactly certain where it is on a 1999, however, it is definitely located behind the grille, or possibly on a frame horn. The wire harness you're looking for will dead end at the sensor. One thing for sure, it's not the sensor with a yellow connector. That is a sensor for the SRS (air bag). BTW the "OC" may stand for "open circuit", just a guess.
ypelchat
01-01-2006, 12:07 AM
Thanks! :smile:
Yves.
Google
Web AF
