96 camry powersteering fluid leakbz2fx8 12-14-2005, 10:26 AM Hope you guys can help on this problem. I have a leak that is coming from the rack-n-pinion.It's underneath the drivers side. It looks like it's coming from a port like hole with a big screw on it. It seems to be leaking from the screw threads. I have added Lucas sealent for power steering but that didn't seal this leak. I have checked for leaks thru the rack,pump and reservoir and this is the only leak I see. Is there a seal kit or do I have to replace the whole rack-n-pinion?Any suggestions? Toysrme 12-14-2005, 04:18 PM Flush the powersteering before the lucas crap does something bad. I'm not sure which point you're talking about on the P/S unit, but if it's simply leaking past a screw you could always back it out, apply a dab of ultra black RTV, or a plasticizer (Blue loctite) & see if it quits leaking once the sealer dries out. (I'd wait 12-24 hours) Are you SURE it's not leaking at a pressure tube, or maybe the steering gear boots, or something? Can you take a picture, or find a diagram of it in the factory service manual & circle it for us? bz2fx8 02-06-2006, 09:07 AM I have decided to go ahead and replace the rack-n-pinion, and I need some suggestions. Should I buy the parts from toyota dealer or from autozone? Do you guys have a place that I can buy aftermarket parts? I have never done this, do you guys have any suggestions? I also wanted to ask you guys if I should replace the oxygen sensors? My car has 127,300 miles and I have never replaced any of them. I believe there are 2 or 3 oxygen sensors. Should I get them from the dealer or after market? Thanks for your advice! gator2764 02-06-2006, 09:12 AM I need to replace the rack on my 95 Camry...Going to go to Advance Auto and buy it, hell of a lot cheaper than the dealer I am sure. bz2fx8 02-06-2006, 01:44 PM Hey guys, I meant 197,200 miles. Brian R. 02-06-2006, 01:55 PM You can rebuild the rack assembly. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
