Power Door Locks SLOWwkumale 12-14-2005, 10:01 AM 96 Cherokee - Power Door Locks work great in the front bu tthe back ones hesitate and i have to hold the unlock button up for a second for them to unlock. Can these be lubricated or greesed or is this a result of motors getting weak? It only happens to the back ones. - TJ Jeepme 12-14-2005, 09:53 PM It sounds like they could be binding up. I would take the door panels off and check the functioning of the power lock solenoid. If it seems to be all right, lube the linkage at all pivot points as well as the latch. That was all it took to free up mine. mackamitsu 12-16-2005, 12:26 PM you may also have oo much lube, and if you live in an area where it gets cold, the lube will slow down response time. vamc 12-17-2005, 02:49 PM we have a 95 and the same thing, they need lubercated, take off the dorn panel and greese them up, and your set, thats what you need. DIGITRUCK 12-18-2005, 08:16 AM Hey, What kind of grease is good to use on the pivot points? Can I use the same type that I lube the undercarriage with? Thx, Phil oljeeptek 12-18-2005, 01:39 PM I've used spray lithium grease, clear silicone grease and chassis grease over the years inside doors with good results. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
