remote startersrhodey60 12-07-2005, 11:02 PM id like to no if a remote starter would work on a 04 nissan sentra the reason i ask they have a chip in the ignition key nismowu 12-08-2005, 01:22 PM well......if that "chip" thing is for real, then the engine wouldn't start without the key, so no, remote starter wouldn't work. btw, take care of your keys, it costs about $180~$250 for a new key fugiot 12-08-2005, 03:58 PM I believe some remote starters are programmable to send the same signals as the keys would. Obviously, only the more expensive ones can do that though. Mailt4 12-08-2005, 05:26 PM Anything is doable these days, I charge around $ 200.00 to get one done, there are bypasses that you can use with out doing anything to you Key/Alarm system, keep everything original, Your Wirings MODEL YEAR(S) SENTRA 2000 -2005 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key PART COLOR LOCATION 12 VOLT CONSTANT WHITE/RED (+) IGNITION SWITCH HARNESS STARTER BLACK/WHITE (+) See NOTE *1 IGNITION SWITCH HARNESS STARTER 2 BLACK/YELLOW (+) See NOTE *1 IGNITION SWITCH HARNESS IGNITION 1 BLACK/RED (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 WHITE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 WHITE/BLUE (+) IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) WHITE/RED (+) or RED/BLUE (+) IN DRIVERS KICK PANEL or HEADLIGHT SWITCH POWER LOCK GRAY (TYPE B) @ SECU, See NOTE *2 POWER UNLOCK PURPLE/RED (TYPE B) @ SECU, See NOTE *2 DOOR TRIGGER See NOTE *3 @ SECU, See NOTE *2 DOMELIGHT SUPERVISION RED/YELLOW (-) @ SECU, PIN 8, See NOTE *2 TRUNK RELEASE RED (-) @ HATCH RELEASE SWITCH SLIDING POWER DOOR N/A HORN WHITE/GREEN (-) @ STEERING COLUMN HARNESS TACH ANY WIRE BLACK/RED, PURPLE, BLUE/RED or GRAY/RED @ ANY IGNITION COIL WAIT TO START LIGHT N/A BRAKE RED/GREEN (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM WHITE/BLUE(-) @ SECU, PIN 30, See NOTE *2 ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER EXTRA INFORMATION NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold. NOTE *2 THE SECU (Security Electronic Control Unit) IS LOCATED TO THE RIGHT OF STEERING COLUMN. NOTE *3 ON VEHICLES WITHOUT POWER DOORLOCKS USE RED/WHITE (-) IN DRIVERS KICK PANEL. ON VEHICLES WITH POWER DOORLOCKS, USE RED (-) FOR DRIVERS DOOR AND RED/WHITE (-) FOR PASSENGER DOOR, WHEN CONNECTING TO AN ALARM SYSTEM USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, See DIAGRAM vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
