heater malfunctioning HELPthetalker1255 12-07-2005, 08:33 PM I can let my quest 2000 idle for 15-20 minutes and have the heat turned on , but it will still blow out cool air. As soon as I put my foot on the gas pedal and accelerate I get hot air; foot off---cool air. This is very frustrating in the cold winter. Any ideas? A mechanic has already flushed and filled the antifreeze and checked all the vents. kellybo01 10-14-2006, 07:08 AM The issue may be the impellors in the water pump... they get worn and will not push the water through your system unless the accelator is pushed.... just a guess.... FixUrNissan 10-17-2006, 06:17 AM I can let my quest 2000 idle for 15-20 minutes and have the heat turned on , but it will still blow out cool air. As soon as I put my foot on the gas pedal and accelerate I get hot air; foot off---cool air. This is very frustrating in the cold winter. Any ideas? A mechanic has already flushed and filled the antifreeze and checked all the vents. Double check coolant system for leaks, replace any needed components found leaking. I would Double check you don't have any air pockets also . Air pockets could give you same symptom especially if you have rear heat. dzus 10-19-2006, 08:27 AM I would bet my mother-in-law that it's air in the coolant system. Automotive Network, Inc., Copyright ©2012
