1992 Camry LE V6 3.0L engine..Jbones 12-07-2005, 02:52 PM Hi, I want to put in a new air filter which I thought would be simple since all you should do it take off the clips but I noticed I have to take the whole tube off to put in, could anyone tell me if I have to do all that or should be just simple and take off the clips that's all??? Toysrme 12-07-2005, 11:58 PM It's best to take the rubber hose off the TB & AFM (They split easily once they're old.), but you can do it without it. After that yes, 4 clips & pull up. Don't rip the AFM's wiring out if you're gonna remove it completely. There is a wire that clips it in place, then you pull it out. If you just unscrew the screws & pull the wire, it'll rip all the elctrical connectors off the electronic PCB inside the housing. Jbones 12-08-2005, 04:03 AM Thanks so much man but seems like something maybe I should let the mechanics do for me, not something I should fool around. Toysrme 12-08-2005, 03:30 PM What, exactly, is too complicated, or hard about 4 clips. Just don't go bending your hose around too much. (Take that as a mother bird pushing a baby out of the nest, not as beaing mean.) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
