Jump start from 1996 Chevy Luminabobinwi 12-06-2005, 01:02 PM I want to use my 1996 Chevy Lumina to jump start my wife's dead battery. I have located the "remote positive terminal" for the battery in the Lumina, but the jumper cable can't reach the negative terminal. Is there a way I can work around this? Thanks in advance. Schurkey 12-06-2005, 06:05 PM Snap the - jumper lead onto the engine lifting ring. Might have to wiggle it some to get to bare metal instead of black paint. bleepster 12-07-2005, 07:20 AM if his Lumina is the good car - he needs to put the cables on his Positive AND negative battery terminals, to his wife's Positive on her battery, and then he can ground out the negative. So, I don't think your reply is accurate. My neighbor needed a jump, and I wanted to use my '04 Venture, and i couldn't figure out how to get to my negative terminal on my battery. i ended up getting my '81 Trans Am over there to jump her car for her. so - i re-ask the question, how do you get to the negative terminal on these vehicles???? Schurkey 12-07-2005, 10:05 AM You do NOT need to get to the negative terminal on the battery. You only need to get to a hefty piece of metal that is securely CONNECTED to the negative terminal of the battery. Snap onto the lift ring of both engines... bleepster 12-07-2005, 10:38 AM thanks Schurkey, that i didnt know. will keep that in mind for future reference bobinwi 12-07-2005, 11:28 AM Thanks Schurkey and bleepster -- Not sure where the engine liftiing ring is; I'll have to try to look that up. But I clamped onto a bare part of the engine (in both cars) and everything worked out. That is, at least I didn't kill the Lumina. My wife's car cranked, but didn't start. We're getting it towed. But with your help at least I didn't make the situation worse. Thanks. corning_d3 12-07-2005, 09:41 PM Don't worry about messing up the dead car, worry about sending a voltage spike to the running cars computer and frying it.... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
