safety boost mode?
TeamRedLine23
12-05-2005, 09:41 PM
I was on the freeway boosting 10 psi then I shifted to fourth gear and it only boosted 6-7 psi. So I got off the freeway turned hte car off and looked to cracks in the all the intake hose no cracks that I can see. so after about 5 min. of he car just sitting I started the car and it ran fine 10 psi from 1-4 gear when I hit 5th 6-7 psi. sometimes it runs 6-7 psi 1-5 gear. what could this be? thanks
DeleriousZ
12-05-2005, 09:45 PM
uh what rpm are you shifting into 5th at?
TeamRedLine23
12-05-2005, 09:47 PM
5,000 rpm
DeleriousZ
12-05-2005, 10:07 PM
sorry i meant what do the rpm's drop to lol...
TeamRedLine23
12-05-2005, 10:26 PM
lol, the rpms dont drop. the rpms keep going up but it just wont boost past 6 psi or so. but when I turn the car off it will run fine 10 psi for a while then the boost just suddenly drops.
k3smostwanted
12-05-2005, 10:59 PM
go buy yourself a boost leak tester...
how many miles are on your Z?
TeamRedLine23
12-06-2005, 07:29 AM
it has about 96,000 miles.thats what I was going to do next. its sounds like there is air leaking out of the lower intake hose on the passanger side. but I did run the codes and it came back as code 55.
k3smostwanted
12-06-2005, 05:05 PM
sounds like a boost leak...get a boost leak tester and check EVERY connection. beings the Z32TT is a Boost Piping nightmare, leaks are notorious for the Z32. good luck!
TeamRedLine23
12-06-2005, 05:42 PM
thanks for all of your help
k3smostwanted
12-06-2005, 05:47 PM
no problem...also check your recirc valve if you check all other connections. remove the return hose to the charge pipe and hold your hand over while someone revs your engine. if it is leaking then you need a new recirc valve...
just pray that your wastegate actuator isnt malfunctioning or you have a crack turbo housing. both would involve pulling the motor.
like i said...good luck and you are very welcome!
also, are you reading a stock boost gauge or an aftermarket?
DeleriousZ
12-06-2005, 07:45 PM
what's with you and double posts?
k3smostwanted
12-06-2005, 07:50 PM
FIXED!
whats up with you and caring? :loser::D
DeleriousZ
12-06-2005, 07:54 PM
it's annoying
k3smostwanted
12-06-2005, 07:59 PM
it's annoying
you going behind everyone making sure they spell every word correct is annoying! :rofl:
DeleriousZ
12-06-2005, 08:02 PM
maybe if you learnt how to spell the first time we wouldn't be having this conversation
k3smostwanted
12-06-2005, 08:06 PM
maybe if you had learned how to spell the first time we wouldn't be having this conversation
what is that, Past progressive? i was a class A grammar student in high school but i have forgotten some of my skills. :D
DeleriousZ
12-06-2005, 08:11 PM
learnt is an abbreviation for had learned... i scored perfect on the grade 12 language proficiency test, so don't test me... :D
k3smostwanted
12-06-2005, 08:14 PM
we dont use learnt in the english language, i dont think. and yes i scored a 34 on my ACTs in english/grammar. so dont test me!!!
and thats a 34 out of 36 in case everybody else is on the SAT format.
DeleriousZ
12-06-2005, 08:16 PM
learnt Audio pronunciation of "learnt" ( P ) Pronunciation Key (lūrnt)
v.
A past tense and a past participle of learn.
http://dictionary.reference.com/search?q=learnt
k3smostwanted
12-06-2005, 08:19 PM
v.
im telling you....you say that around here an english teacher, they will correct you and tell you that you arent 3 years old anymore.
DeleriousZ
12-06-2005, 08:21 PM
and it's not for 3 year olds, they'd say learnded or something like that... it's commonly used as shorthand... and don't say it's a canadian thing because it's used all over the english speaking world... besides, what's america's illiteracy rate? like 54% or something?
k3smostwanted
12-06-2005, 08:26 PM
i know, i have heard the word learnt before and i know it is a word. but i was taught that it is not grammatically correct. go ahead...come to my area, they will look at you stupid.
illiteracy? i dont think we are that illiterate...probably like 3% illiterate.
is everyone literate in english? i doubt it...we have lots of mexicans that cant speak a lick of english and for some reason we have lots of people that have lived here their whole lives that cant speak a lick of english either, they call it ebonics...i call it ignorance.
TeamRedLine23
12-06-2005, 08:38 PM
I have aftermarket bovs. and its the stock boost gauge.
k3smostwanted
12-06-2005, 08:42 PM
ahh...dude. you cant tell anything from that gauge. its about as worthless as wiping before you poop.
make sure your BOV's are clamped down tight and not leaking.
TeamRedLine23
12-07-2005, 12:20 PM
so I guess Im going to have to invest into a new boost gauge. I was thinking to get two boost gauges onefor each turbo incase something is wrong with one turbo I would know.
TeamRedLine23
12-07-2005, 12:25 PM
I need a new power transister unit. the one on my car is not making a good connection. so I cleaned it but that just made it even worse. it wasent te acutal cleaning of the conncetors it was when I had to twist the wires to get to the back of the c-clicp. oh well they recalled them anyways.
k3smostwanted
12-07-2005, 05:51 PM
i think it was only on recall for the 1990's. the 91's+ should have the newer style.
ya better get one before it fails completely. i would fix that before worrying about your boost problem.
