84-89 300zx potentialdjcrypt 12-05-2005, 05:35 AM hi all, my friend is looking to purchase 1. is it worth getting it, how many problem can he can expect? thanks in advance...jim stephenp 12-05-2005, 12:17 PM ..... need alot more info than that to give a good answer.. how many miles? is it turbo? ios it t top? is it digital or analog? electronic adj suspention? do the windows leak(rear quarter glass) t tops often leak and the seals are expensive digital dash has tendency to stop working although this problem can usually be fixed relatively cheaply if you know what your doing ac units usually need rechargeing every other year rear window leaks if left unattended lead to holes in floor board that arwe the same place that the rear suspentin links to this is an interference motor meaning change the timing belt and whebn doing so remeber to first remove rocker shafts(no big deal) those are basicly it for the cons as for the prosa the lists goes on and on if its turbo it is one of the simpilist turbo systems ever created meaning that the diy can bolt on parts and no need to reflash until you exceed the realm of normal bolt ons( minor bolt ons) and as for performance with it being a older car the bolt ons are not very car specific yto these you have to get universal like a cone filter (near cold are due to design ofd intake put on an exhaust and a boost controller and boost the psi otom say 8 psi and set timing to 22 degrees btd instead of the recomended 20 and you got a nice additioin of power from styock and you should be able to smoke all those gsr and type r blah blah bl;ah hondas good luck xXxRocker5150 12-05-2005, 03:21 PM tell him to get an 87+ turbo; IMO they're the best looking, and they come stock with an LSD... I think they have 5 extra HP too, but I'm not sure on that one (Delerious or LLZ correct me if I'm wrong), but other than that I think pretty much everything's been said... also check out z31.com you can find out alot there DeleriousZ 12-05-2005, 07:11 PM yeah they come with a different turbo (slightly) which gives them a bit more hp... as for potential, with the turbo, the sky/your wallet is the limit for performance, just depends what your goals and budget are... as for the n/a, it's not worth getting unless it's a. a super good deal (ie. free or in really really good condition) b. heavily modified already (we're talking higher comp pistons, head work, all that super expensive stuff) or c. you can't afford a turbo which isn't likely as they're dirt cheap almost everywhere you go... what's he looking at? as in year, miles, turbo/non turbo, 5 spd vs automatic... DeleriousZ 12-05-2005, 07:11 PM oh and if you can understand that stephenp guy you're 1 step ahead of all of us... k3smostwanted 12-05-2005, 07:46 PM oh and if you can understand that stephenp guy you're 1 step ahead of all of us... make it two steps... step 1 = taking the time to actually try and decypher it step 2 = understanding it. djcrypt 12-05-2005, 08:53 PM he is looking at the analouge dash, open minded in terms of turbo/NA, auto or man, targa preferbly. that is all that he likes, all else are insegnificate details. Any other major problems that are assosiated with 300ZX? thanks heaps to every1 who posted!!! xXxRocker5150 12-05-2005, 08:58 PM there will be problems if the previous owner beat the hell outa it and didn't do maintenance... the one main problem with z31's is the injector recall, but most have already had it done... if he wants performance, than get a turbo, no questions asked... if he wants something nice looking to cruise in that could potentially hold about 3 pasengers... get an n/a 2+2... but the 2 seaters look better DeleriousZ 12-05-2005, 09:44 PM turbo 5 speed is the way to go then, its VERY rare to find a z31 in slicktop (no T-roofs) so he probably won't have to worry about it.. as for problems, there isn't really anything major, just make sure to find out when the timing belt was done, that's prettymuch the biggest maintenance issue you'll find with the 300zx's z31 or z32... they are known for having a few random electrical gremlines, but they can usually be resolved pretty easily.. make sure to look for rust.. EVERYWHERE on the car.... nissan's are Notorious for hiding rust... if it's just surface rust it's no problem, the stuff you'll want to look out for is if it's rusted thru anywhere, especially underneath the car... either way, good luck, i'm sure your friend will find the zed for him djcrypt 12-06-2005, 09:29 AM thanks a bunch, this HAS helped... now ill have some competition...lol thanks again k3smostwanted 12-06-2005, 05:04 PM make sure to look for rust.. EVERYWHERE on the car.... nissan's are Notorious for hiding rust... if it's just surface rust it's no problem, the stuff you'll want to look out for is if it's rusted thru anywhere, especially underneath the car... pre-90's Nissan's are notorious for rust! :D 87+ 2 seater 5-speed turbo. if you have some cash and any luck you may be able to find yourself a 88 Shiro. DeleriousZ 12-06-2005, 07:38 PM no go with an 88 shiro or not, some of the 87 turbo's didn't come with an lsd... the ones made after a cirtain month did but unless you actually get under the car and look there's really no way to tell when test driving the car (depends how hard you test drive:p) actually, tell him not to get a shiro edition first off... everyone should gain a respect for the Z before they can own a special edition one... xXxRocker5150 12-06-2005, 09:03 PM I got fucked up the ass on the LSD man, cuz my car was made in 9/86 .... all the 87's made after like 4/87 have an LSD k3smostwanted 12-06-2005, 09:15 PM actually, tell him not to get a shiro edition first off... everyone should gain a respect for the Z before they can own a special edition one... i suppose this has a relevant point behind it........... .....thats a first from DZ! :rofl: DeleriousZ 12-06-2005, 09:49 PM i suppose this has a relevant point behind it........... .....thats a first from DZ! :rofl: har har, you know i'm the master of relevancy:p k3smostwanted 12-06-2005, 09:50 PM har har, you know i'm the master of relevancy:p your the master of conservativity!!! :D DeleriousZ 12-06-2005, 09:51 PM i'm not conservative, i'm practical k3smostwanted 12-06-2005, 09:52 PM i'm not conservative, i'm practical conservative and practical! :loser: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
