1999 durango 5.2 cranks over fine wont start
borninabarn
12-04-2005, 04:33 PM
the 1999 durango was having a no start problem replaced the fuel pump seemed to work fine for a few days then same problem thought the security system might be it took it completely out and it started again thought was fixed drove it for 2 days no it wont start again anybody know whats going on with this vehicle? thanks
git-r-done
12-05-2005, 11:25 PM
if your "check engine light" is/was on, or it might work just to figure out if the computer has any codes relating to this stored. turn the key to on to the accesories position 3 times and on the third time look at you odometer, and if it is digital it may have a trouble code. if it gives you a trouble code figure out what it means, if you have a haynes manual it should have them in it. i know the one for out 2001 does. if that doesnt work for you, im sorry
best of luck
borninabarn
12-06-2005, 07:41 PM
best of luck
the durango doesnt show any codes on a genisys scanner i will try the key thing tommorrow havent pulled it back in the shop yet been below zero back here in iowa.as you can imagine how busy it is now! thanks for the advice.
borninabarn
12-07-2005, 09:34 PM
Went out and started the thimg it started right up now drive it for 1-2 hours and the truck will die again and will have to wait a few days till it starts again.any ideas techs thanks
borninabarn
12-13-2005, 09:14 PM
Put a new fuel pump relay in already replaced the fuel pump seems to be doing goo so far?
borninabarn
12-26-2005, 04:44 PM
Put a new fuel pump relay in already replaced the fuel pump seems to be doing goo so far?Once again this thing wouldnt start banged on the relay box under the hood started right up again?For now any ideas?
wafrederick
12-26-2005, 06:22 PM
Might be a bad computer or in the security system.I know Blue Streak America rebuilds them and it is a waste of money.All Blue streak needs is the vin and the mialage off the vehicle.Went throught last month,One would not start when after getting it back.Go with a reman computer from Chrysler and the vin has to be burned with Chrysler's factory scan tool,DRB III or with a Vetronix scan tool.An OTC scan tool or a Snap On scanner will not do it
borninabarn
01-07-2006, 02:21 PM
Thanks for the info!Better try that my tech put another fuel pump in this thing a dodge one this time he thought maybe the aftermarket one was bad.Wrong answer this unit is sold and went out to bring it in and wash no start again.It had a dealer installed security system in it we took that out.started fine but the problem still exist.FFFing thing!so do you think replace the ecm or the bcm? let me know master techs!Thanks
wafrederick
01-12-2006, 12:22 PM
Replace the whole ecm and there is a core on the old one.
borninabarn
02-03-2006, 09:16 AM
[QUOTE=wafrederick]Replace the whole ecm and there is a core on the old one.[/QUOTErEPLACED THE PCM 4 WEEKS AGO BEEN RUNNING FINE UNTIL YESTERDAY CUSTOMER CALLED NO START AGAIN WENT TO PICK UP THE VEHICLE AND IT STARTED RIGHT UP IGNITION SWITCH MAYBE?
borninabarn
02-12-2006, 07:50 AM
[QUOTE=wafrederick]Replace the whole ecm and there is a core on the old one.[/QUOTErEPLACED THE PCM 4 WEEKS AGO BEEN RUNNING FINE UNTIL YESTERDAY CUSTOMER CALLED NO START AGAIN WENT TO PICK UP THE VEHICLE AND IT STARTED RIGHT UP IGNITION SWITCH MAYBE?Well still havent tryed the ignition switch put this vehilce in the shop where it it warm it will start park it outside where its cold 25 degrees wont start again banged on the gas tank outside it will start maybe got a bad fuel pump if so this will be the 3rd one aftermarket 1st time factory one 2nd hope the will warranty the factory one also replaced the air temp sensor on the intake thought maybe with the temp change that could be it but that didnt change anything
Philthyone
02-12-2006, 09:08 PM
I have had this same problem on my 2001. It would not startup unless I was stepping on the gas, and once it started, it would not idle. I found two threads here that pointed to the Throttle Position Sensor. You probably need to replace it. (About 38.00) However, there is a workaround that may get you through awhile. Simply disconnect the battery for a minute or two. This seems to reset the on board computer. Once I did this it started right up and ran fine. This was about two months ago. So far so good. Still have not replaced the sensor though.
Good Luck.
