Air on continuouslyCHEVYdriver89 12-04-2005, 03:26 PM Hey, I have a 2001 Chevy impala and today I started it (VERY COLD DAY) and turned on the air to full #5 and then turned it down and it was working fine... Then I turned it to full and again leaving the car running, and ran inside to get something, i came back out and started going then when i turned the air to off it kept blasting at 5! i pulled over and turned the car COMPLETELY off and it STILL kept going, I went home, checked the fuse for "HVAC BLO" it was fine, i took it out and it stopped the number 5 and it still allows 1,2,3,and 4 to work, so i have the fuse out, sorry for the long post but doesn anyone have any suggestions? bigrod118 12-04-2005, 05:12 PM I know someone else knows some more info about his and how it exactly works, I forgot. but the 5th setting is thru different wiring gets it power directly from the batter trhu a bypass, so it proabably has something to do with that. ill try to find the last post where I read that. EDIT: here is the link it doesnt reallt tell you how to fix it, but it tells you wht the problem is, yours is just the opposite. http://www.automotiveforums.com/vbulletin/showthread.php?t=487657 heres another one, explains a little better. http://www.automotiveforums.com/vbulletin/showthread.php?t=381354&highlight=fan Ok, I figured your next question would be how to replace the resistor, so I got the instructions for you. http://i18.photobucket.com/albums/b146/bigrod118/100_1042.jpg http://i18.photobucket.com/albums/b146/bigrod118/100_1042_00.jpg vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
