1985 4-Runner rotor/bearing/shaft locking nutSidneyCanada 11-29-2005, 08:58 PM Anyone know the specs for the locking nut and bolt that allows the rotor to be bolted to the bearing and rotor and shaft on a 4x4 1985 4-Runner with the factory SFA=solid front axle?.Thanks in advance. Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM Brian R. 11-29-2005, 11:28 PM I will assume you are talking about the adjusting nut that preloads the wheel bearing.... Install the thrust washer and adjusting nut Tighten the nut to 43 ft-lbs Loosen the nut until it can be turned by hand Retighten the nut to 35-60 in-lbs then turn the hub two or three times to be sure it moves smoothly with no play in the bearings Pull on one of the lug studs with a spring balance perpendicular to the radius of the hub. The correct pre-load is 6.2-12.6 lbs Loosen or tighten the nut to obtain the correct pre-load. Install the lock washer and locknut Tighten the locknut to 58-72 ft-lbs Secure the locknut by bending one tab over the locknut and one tab over the adjusting nut SidneyCanada 11-30-2005, 06:02 AM Thanks but I needed the specs for the bolt so that I can buy one. Brian R. 11-30-2005, 07:28 PM What bolt is that? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
