Car sometimes feels like it moves while sitting stillspunger 11-29-2005, 04:51 AM Hey guys, I have a 2001 Blazer LT 2x4 and it's got the 4.3 v6. Sometimes when I go to start the car after it's sat for 8hrs or longer when you feel the car turn over, it feels like the car moves a little bit. It's been a feeling that has been happening now for a few months, and not everytime. If you drive the car and don't let it sit you never feel this, but it sorta "feels" like the car moves forward a little bit. It's just a weird feeling but if it's something easy to fix I'd go ahead and do it. Any ideas on what could cause this at startup and such? Everything has just been done to the motor (new plugs, air filter, wires, oil etc...) and I've only had the truck for a couple of months. It has 75,xxx miles on it. Any help would be greatly appricated! OverBoardProject 11-29-2005, 10:26 AM If it's a standard your clutch is draging a little. Then the best cure is just stick in in neutral for starting Plus you might want to bleed the clutch if possible. Check the fluid level wolfox 11-29-2005, 12:55 PM Inner ear infection? I had a coworker that got one and would suffer vertigo and or sensation of movement when sitting in a certain position or moving to sit in a particular position. ;) OverBoardProject 11-29-2005, 01:38 PM Intresting theory wolfox, and you might be right. I had a VW van that had a draging clutch, that's why I sugested it. It's actually a ppretty common problem where I grew up with the air cooled VW's, especially durring the wet winters spunger 11-29-2005, 02:57 PM No, it's an automatic, LOL no 5sp here! It's just a weird feeling, no I don't have an ear infection or anything. It's like the far feels like it moves an inch or 2 forward when starting the car but only after it sits for 8-10hrs. It doesn't seem to effect driving and such, just an odd start up feel. MT-2500 11-29-2005, 03:19 PM Before you start it see if you can push it forwards or backwards. Or before you let sit push forwards or backwards and make sure it is locked in park. A lot of them will move a in. or so in park. Just be sure it is locked in park gear. MT wolfox 11-29-2005, 05:59 PM I used to have a CJ-5 Laredo that I could not leave alone on a hill. It was a 5-speed, and I would have to leave it parked in gear. When it got cold out, for some reason the parking brake would not hold. It would release all by itself. One time, I parked it out back behind a television studio to stop in to drop off a stack of tapes. When I was going outside, a bunch of people rushed to run past me, and three security officers. When I got outside, wondering what the panic was about, they were running to go and catch my truck before it rolled out of the lot into traffic! It was parked, out of gear (neutral) with the brake applied. It just let go and slooooooooooooowly started to creep out of the lot, downhill toward the entrance and out into traffic. The sharp eyed security staff caught it moving on one of the parking lot cameras. :D :lol: I could never get the brake to release by itself when I was *watching* it. I stood out in 20 degree weather, freezing my butt off to see if, when and how it would just let go. After 25 minutes I stubbed my cigarette out, turned my back to it to go walk back in the house when I heard it pop. "CHUNK" The truck rolled backwards until it was resting on just engine compression in my driveway. Could never find what was wrong with it - and it would ONLY do it when it was below freezing. Damn thing was haunted, I swear. OverBoardProject 11-29-2005, 08:33 PM I like Jeeps, and the CJ5 is my second favorite, but never buy an automatic. A friend of mine bought 1 at an estate sale, and even though it didn't have any damage it turns out that it had rolled killing the former owner It almost rolled on my friend several times. He sayes that it just wouldn't hold back when you needed it to. And shortly after he sold it I understand that it rolled again killing another person. Even though it still didn't have any real damage they finally crushed it. laxman21 11-29-2005, 09:46 PM Did you by chance take the brown acid? ;) It could be from the engine shifting the center of gravity and you rolling just a bit. OverBoardProject 11-29-2005, 09:59 PM Did you by chance take the brown acid? ;) It could be from the engine shifting the center of gravity and you rolling just a bit. Is brown acid beer? Just wondering. It's a term that i've never heard mike2004tct 11-29-2005, 10:21 PM Is brown acid beer? Just wondering. It's a term that i've never heard By the poster name, I'd say Ex-Lax. Ever get that feeling at a stop light where you think you're moving backwards. Actually it's the car next to you creeping forward, but you instinctively jam the brakes a little harder? (may be an old age thing, like Alzhiemers, and the need for a laxitive) laxman21 11-29-2005, 11:11 PM Is brown acid beer? Just wondering. It's a term that i've never heard Woodstock ring a bell? corning_d3 11-30-2005, 12:09 AM When a vehicle sits for a while, the clutches inside the transmission can stick to each other, so when you start the vehicle, it feels like it's trying to move, but just as quick as you start it, the clutches break loose.... It's really noticable with a newly rebuilt transmission. blazes9395 11-30-2005, 01:09 AM It could also be a sticking brake caliper, when you go to jump in it and start it up, if the parking prawl hasn't totally engaged, it will move a little until it locks completely. Rmbodie 11-30-2005, 03:43 AM Don't take the yellow pill anymore either . How does the tranny fluid look ? first thing I thought was the clutch bands sticking . Had this happen on a motorcycle because of dirty oil . Even if it is a different system . Same multidisc clutch system . The internal park lock pin may be damaged . May have one too many parks without brake and that loud clank when when you pull the shifter to a gear.Rob sirruggie 11-30-2005, 05:25 AM Don't take the yellow pill anymore either . How does the tranny fluid look ? first thing I thought was the clutch bands sticking . Had this happen on a motorcycle because of dirty oil . Even if it is a different system . Same multidisc clutch system . The internal park lock pin may be damaged . May have one too many parks without brake and that loud clank when when you pull the shifter to a gear.Rob It may be that the fluid settles in the bottome of the pan and all bands and clutches are dry. This will allow friction when the engine is being cranked. Most cars that are automatic can now be push started at around 25 miles an hour and because of the setup it can cause the tranny to pull a little upon a cold start. Don't ask for the specifics of all this, but it is not harmful to the tranny. blazee 11-30-2005, 05:50 AM Ever get that feeling at a stop light where you think you're moving backwards. Actually it's the car next to you creeping forward, but you instinctively jam the brakes a little harder? I love putting it in reverse and rolling back a little, and watching the driver beside me jump because they think that they are rolling out in to traffic. BlazerLT 11-30-2005, 11:42 AM This kinda sounds like a situation where the transmission needs servicing. A fluid and filter replacement would probably stop this is it is indeed a physical problem. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
