Key is stuck in ignition on a 96
Google
Web AF
Daniel Blair
11-28-2005, 06:14 PM
What a great site this is!!!
Here is my problem. The ignition key in my 96 Bravada/Blazer won't turn all the way back to the off position so the key can be removed. I found that there is a small solenoid in the column that prevents this unless the vehicle is in park. I have replaced the solenoid but that wasn't the problem. There must be a switch somewhere that activates this solenoid that I can't find. Does anybody have any idea where I should look next? Is there a switch in the floor shifter or in the transmission that activates this solenoid or am I barking up the wrong tree entirely.
Thanks for all of your help.
Dan
jsgold
11-28-2005, 08:07 PM
Do not know if this will help but, my 93 S-10 went through this just 4-5 months ago. I had to replace the ignition key switch assy. Just worn out and needed replacing. The switch in the column was fine as was linkage etc.
laxman21
11-28-2005, 09:44 PM
Same thing happened to me while it was running. Had to replace the ignition lock.
Google
Web AF
