pulsing/surging problem
Google
Web AF
wxlk06
11-28-2005, 02:40 PM
2000 Pontiac Grand Prix GT 3.8 72K Miles
Car has a surging/pulsing problem. When running at highway speeds if I attempt a slight increase in throttle to overcome a grade increase car will surge. Can be seen on tach as it increases & decreases several times per second (I call it pulsing). After grade car runs normally. Vehicle has no other issues and no engine light comes on. Any help appreciated - Bob
richtazz
11-28-2005, 03:27 PM
I would check your pcv valve. The MAP sensor receives it's vacuum signal thru the pcv, and when the pcv starts to get dirty, it will cause part throttle/high load surges and hesitations before it get bad enough to trip a code.
wxlk06
11-29-2005, 08:06 PM
Rich,
Tnx for the reply. I'll replace the PCV valve and report back the results.
Bob....
yakman
12-30-2007, 12:20 AM
Did the PCV replacement fix your car ?
Mine is same car with 80K and doing same problem slight acceleration in 40-50 mph range causes surging that can be seen on tach too .
Any help would really appreciate !! THANX Dave
BNaylor
12-30-2007, 12:31 AM
Sorry but please check the date and do not resurrect or slave off of old threads. Best to start a new thread/post to address your issue to the forum. Also, be sure to include the year Grand Prix, model or engine.
Your problem sounds more like a TCC related tranny issue aka "fishbite/"chuggle"or possibly a secondary ignition problem.
This thread has been closed.
Google
Web AF
